Hey All,
Building an AB165 Bassman clone but with some changes to the bias supply & adding a Master Volume (I know, that goes against my previously stated principles). I wanted to have a Bias Balance & Adjust but didn't have any tapped pots like the SF amps, so I opted instead for a Bias Adjust pot for each tube.
I followed the standard BF wiring of the pot, but I know there's a way to wire it so that if the pot fails, you have max negative voltage on the grids? I've got my best guess on my drawn picture but wanted to run it by here.
Both supplies are the same right now, so I'm thinking I can test changes on one & use the other as a "control," with no tubes installed. I'd like to stick with basic pots & resistors here, since I'm not even sure which way to draw a diode in circuit...
I can tweak resistor values as needed; these are just starting values that seem pretty standard.
Also wanted to make sure my MV is safe here? I'm not concerned with "sonic results" at the moment, just want to make sure I won't cook my tubes. I'm thinking the only change I need to make on the MV is to not link the ground terminals on the dual pot, since I have individual bias pots?
Thanks,
Jusrin
Thanks,
Jusrin
