I think your schematic is fine. The reverb level control shouldn't affect the dry signal level - I assume that your reverb board only puts out the effected signal, that there's no dry signal mixed in with it? I don't understand what mechanism could cause a resistive potential divider to affect the tone, providing that reasonable precautions are taken to prevent excessive capacitive coupling between the input and output, and the output and ground.
Most any power amplifier is not going to require any appreciable current input, except under heavy overload conditions maybe, and then only to drive (input protection) diode clippers; they generally operate as voltage amplifiers, with high current output capability. Peter.
