I have what may seem to be a bit of a newbie question... but what voltage rating should I use on AC coupling capacitors in between preamp stages? At first glance it would seem you need caps at least rated to handle your +B voltage since they're tied directly to the plate (after the plate resistor). For example, in this schematic: http://www.ax84.com/static/corepream..._Schematic.pdf
The coupling cap C100 does not have a voltage specified while bypass caps C101 and C105 do (25V)
However, there is one case where I have seen voltages specified; The "Real McTube II" pedal. It uses a lower +B voltage but still specifies 200V coupling caps http://www.ax84.com/media/ax84_m152.pdf
Are these needed?? Can I get away without the high voltage caps?
Thanks!
-Matt
Thanks!
-Matt
