I'm curious... has anyone experimented with adding a "safety switch to an amp design? With all of the warnings about killing yourself with the +B voltage and how long the filter caps can stay charged I'm surprised I've never seen this. There are a bunch of different ways to implement something like this.
The most simple would be to just add a momentary switch that shorts one of your preamp plates to ground when pressed.
You could get more fancy by changing the main power switch to a DPDT and using the second pole to switch a similar circuit as described above. So when ever the amp is turned off the plate is shorted to ground.
How about a normally-off micro switch pressing up against the lid of the chassis? When you remove the lid the switch shorts the plate to ground... This carries some risk though as you would have to be sure to put a cap over the switch before powering up the amp with the chassis open...
I will probably integrate one of these options into the tube preamp for my hybrid amp. Any thoughts? I know this seems a bit much... But if safety is paramount then why even risk reaching into the chassis to attach a jumper manually? I like the DPDT option best because you don't have to remember to do anything. When the amp is turned off it's "safe" to work on the circuit. Nice and simple and good for beginners (like me!) who are paranoid that they may forget some safety tips sometimes!
