Long time lurker here, starting my first thread. Thanks for all the info & tips I've already gleaned from so many of you.
I'd like to build a Vibro Champ with Reverb in a fancy cab to keep in my wife's living room. I was planning on chopping off the front end of a PR & mating it with the vibrato/output of a VC. I know I'll likely want to tweak the power supply to get my values once I figure out what the PT will be putting out.
I've built a couple amps, an 18 watt clone, and a 5F11 Tweed Vibrolux clone. Both came out great, but I went mostly by the schematics & didn't have to use too much brain power to get them running well. My question about this is, will mating these two amps really be as easy as plugging the front end of the PR into the backend of the VC? I keep feeling like I'm probably missing something that will keep the amp from working correctly.
I've done some searching for a ready made schematic, but only found the non vibro champ versions previously posted. I mocked up my own from the fender schematics. Any help, concerns or reassurances would be greatly appreciated.
Thanks,
Jay in Philly
Thanks,
Jay in Philly
