Hi everybody,
I have a 560V superlead with an 100w EL-34 OT and I really like the idea of replacing the el-34's which are currently in it with 6550's.
I have a couple of questions about putting 6550's in here:
-The 6550 data sheet tells me to reduce the 220 bias splitters to 47k. Should I do this?
-Should I change the NFB?
-What value of bias current should I go for, using the 1 ohm cathode method?
-Do you recommend 1.5k or 5.6k grid stopper resistors?
-What is the minimum screen grid filtering that you would recommend? I use 32//32uF right now.
Thanks,
Jelle
Thanks,
Jelle
