I just bought the parts needed for the schematic below today. Darn mosfet was $12 ! Anyways, i was going to impliment it just as shown, but i wanted to scale the PA only. However, not having a schematic of how to do that i decided to do the whole amp as the schematic shows. But the more i think about it the more i feel thats not going to work near as well because of my high gain/low voltage preamp.
so heres the question. How would i go about using the circuit below to scale the PA only? I cannot see how i could do that without adding a second main cap can and a second choke. Not that i would even consider doing that, nor could i due to lack of space. But let me explain what i mean and if you can see the error in my thinking please enlighten me. My amp is configured pretty much like a JCM 800 but it's cathode biased. The first thing the B+ sees is the OT, then the 32/32uf cap can with a choke between the cans. after that it goes to the screens via 1k resistors. heres where i see the problem....if i were to scale the PA, the choke and can would be included. In other words, the B+ would go onto the scaling circuit before the OT, then the scaled B+ would come out before the OT. Now if i seperate the PI and preamp from the scaled B+ i would have to take it from before the can and choke at the point where the B+ goes to the scaling circuit. I would have to "Y" the B+ at that point, one side going to the scaling circuit and the other to the PI. Of course i would use diodes to isolate them. But the point here is that the PI and pre are now seeing the B+ as before, but WITHOUT the choke and cap can before them.This is what i don't understand. how can you do this without adding a second can and choke for the pre and PI?
