I'm considering building a hybrid amp consisting of a simple, low power tube amp driving a dummy load (probably a weber MASS speaker motor). The output of the tube amp would be tapped to drive a very clean, high powered solid state amp (~60W).
So, with that in mind... I'm considering using the standard Fender reverb driver circuit as my tube power amp (along with 15K Ohm to 8 Ohm reverb tranny). Most of the Fender schematics I've looked at show both halves of the 12AT7 run in parallel sharing the 15K plate load from the transformer and a 2K2 cathode resistor bypassed by a 25uF cap. Here are my questions (finally!):
-What (if any) changes would be required on the cathode side (resistor and/or bypass cap) to run the output stage at a +B of ~300V?
-Would a push/pull 12AU7 output stage (as used in the Firefly amp from AX84.com) be superior in any way?
-Finally, does anyone have a schematic for the Ted Weber MASS pedal? I glanced at it a month or so ago and remember it using a 12AT "power" stage but since then all traces of the product have been removed from weber's site.
and maybe one bonus question
Am I wasting my time? I hear all the time that to get "that tube sound" you need the whole deal (Preamp, power amp and output transformer) in the mix. I'm considering the cost (and weight!) of a very low power tube amp combined with a high power SS amp against a 60W tube amp.
![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
