Hi,
I floated my 12VDC heaters at ~90VDC because of the CF failure issue discussed previously in Tubes section. I have two 100 Ohm resistors from pins 4 and 5 connected together and then to the 90V point.
Isn't it better instead of using an artificial CT to connect all tubes' pins 9 together and connect them to the 90V?
