Actually it's the other version called VVR, but same principal. I implemented it in a 18 watt converted to 6v6. I first tried it scaling the whole amp. It worked as it's supposed to, however the preamp loses a lot when turned very low. So i then scaled the PA only and for some reason i cannot comprehend, the VVR pot had no effect at all from full up to all the way down. I then set it back to whole amp scaling and again it worked.
I'm hoping someone can tell me what i'm doing wrong. By the way, i added a second cap can and resistor for the preamp because when scaling the whole amp you have to remove the can and resistor from the preamp. so to make sure the pre had the same filtering as before i added that second can/R you see in the schematic. So w/o further ado, heres the schematic showig how i scaled the PA only. note that this is NOT the same amp, but a schematic of my EL34 amp. I just didn't have a schematic of my 6v6, but they are thier PSU's are configured the same except for values.
![](http://i24.photobucket.com/albums/c39/dazco/vvrmod.jpg?t=1229534199)
