I have to builds right now. One is a el34x2 with marshall stype trannys and the other a 18 watt with heyboers converted to 6V6. Both have identical high gain preamps and both are cathode biased with switchable NFB.
the main difference between them besides the output tubes, trannys and different PI values is the EL34 amp has a 20H choke hooked up as in a marshall 50 while the 6V6 has a resistor. The EL34 amp sounds better in several ways and i think this is due to the choke because if i replace the choke with a resistor the amp sounds and feels a lot more like the 6V6 amp.
So logic tells me that putting a choke in the 6V6 amp will make it much closer to sounding like the big amp. But before i go spending money on the choke, can anyone tell me why it won't make the amp sound much more like my big amp? remember....the big amp sounds close to the small one when i put a R in place of the choke. So it seems that doing the reverse should result in the small one sounding more like the big amp. What doth thou think?
