View Post
LDRs as pots?
There are hundreds of silicon-based digital potentiometer and analog switch and routing chips on the market. They can't be used in vacuum tube circuits because they are limited to +/- 15V signal swings at best. Tube preamps can see upwards of 50V p-p.
Mesa's LDR circuit is their attempt at making a cost-effective digital pot that can stand high voltages. It has its drawbacks, which you have found and discussed in this thread, but I can't think of anything else that would work better. The only other technology I can think of is the motorized pots that Fender used in the Cyber-Twin.
The mechanical relay and resistor ladder approach is feasible (it's basically a multiplying DAC) till you try implementing a log taper that way! There are also 400V MOSFET output optocouplers that you could investigate as an alternative to JFETs or relays. Regular optocouplers might even work as audio switches if you connected pairs of them back-to-back.
I guess you could make a circuit that attenuated the signals to digital-pot-IC-friendly levels and then boosted them back up again, but my gut feeling is that the clean channel would end up sounding weak and noisy, and the result would suck about as bad as the SR&D Rockman... It all adds up to enough of a design nightmare that the best solution I can think of would be to buy a used Triaxis!
Good luck getting an answer out of Perkin-Elmer!"Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
The resistor string-relays thing is the most "analog" one but multiply that by 6-10 controls and you'll end up with a 1 sq.ft "pot board".
Using FET switches sounds to me like using digital pots - I would prefer to attenuate the levels and use digital pots as in JMP-1.
The CF is loaded with a typicall Mrashall TS with flat response, then the signal is attenuated to ~1V and goes to the active tone stack.
I was thinking about loading the CF with a flat TS, attenuate the signal and connect /via buffer/ a second tone stack then boost the signal to it's previous levels which makes +1 tube. Now we can use LDRs and forget about most of the problems discussed here.Last edited by Gregg; 01-13-2008, 10:56 AM.
Originally posted by tbryanh View PostI'm not quite following this. It seems that if there are 8 taps in the resistor string, then 8 SPST relays are needed.
Originally posted by tbryanh View PostI am thinking things are far simplier than you indicate and much more possible than you indicate.
Originally posted by tbryanh View PostFrom what I get your saying this approach is not possible.
I WANT your idea to work - that's why I'm pointing to the snags.
Anyway, hope this helps!
I only see 2 issues at this point, distortion and switching time.
Does the LDR Pot distort? (Probably yes)
Does the “rotary-switch” Pot distort? (No)
Does the LDR Pot switch fast enough? (Probably yes)
Does the “rotary-switch” Pot, with its clamp muting, switch fast enough? (Probably not)
Can the “rotary-switch” Pot be made to switch fast without popping? (?)-Bryan
Originally posted by tbryanh View PostCan the “rotary-switch” Pot be made to switch fast without popping? (?)
Critical thing #1 - make sure that in every position, every switching contact on every relay has a DC path to GND. It can be 3M3 or even 10M, but every contact must always have a DC path to GND.
Critical thing #2 - add a diode (cathode-to-(+)) and/or a cap across every relay's coil to contain the flyback currents (induced by collapsing coil field when you 'relax' and energized relay). Make these wires as absolutely short as possible.
Critical thing #3 - use 'low-signal' relays. Regular relays count on the signal current to keep the contacts closed. You won't have that luxury, so you need the relays with the contacts plated/coated with some suitable material. The Omron G5V-2 series, for instance.
Helpful thing to keep in mind - At least some of the pops relay circuits make are due to coil current di/dt getting coupled into the signal runs - (see Critical thing #2) - treat these runs like the noisy things they are - run them at right angles to the signal wires, keep them as far away as practical, and try to slow down the switching edges.
Helpful thing #2 - consider make-before-break switching, and 'walk' the control from current setting to new setting.
Hope this helps!
Originally posted by Don Moose View PostHelpful thing #2 - consider make-before-break switching, and 'walk' the control from current setting to new setting.
I understand the make-before-break switching, but I am not sure what 'walking' means. Please explain if you don't mind?
Thanks again.-Bryan
About the log taper thing, I assumed that you'd use the relays in a binary weighted combination with a R-2R ladder, to save on relays. Binary weighting lets you have a 16 tap "pot" with only 4 relays, but this doesn't work for non-linear tapers. If you're not using this trick then I expect board sizes in the square feet too.
Running relay wires at right angles to signal wires is all very well, but eventually they have to meet at the relay where the coil sits right next to the contacts. I've got reasonable results using RC networks to slow the edge.
I think considering we make tube guitar amps because solid-state ones don't have enough distortion, worrying about LDR distortion is probably pointless. It'll be the same square-law distortion that was once claimed to give carbon comp resistors extra mojo, so if anything I'd expect it to improve the tone.
Did the JMP-1 actually use digital pots or multiplying DACs? I guess Marshall couldn't use the LDR method after Mesa patented it. We don't need to worry about patents."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
IMHO:
Switched resistor arrays seems a good way to go. Problem is the technology used to switch between them. Personaly, I would try Jfets and measure the results on scope, or even using LDRs in an On-Off state and then measure on scope.
The thing is that working in an On-Off state, when its "OFF" its impedance is so high compared to the impedances in the same place of the circuit that the distortion might be negligible, when its "ON" (shunt to ground) its even more negligible.
Its a good place to start experimenting.
1% Distortion we cannot afford even in a tube amp with a 30K impedance at a 1.4VRMS, not just because thats a lot of distortion for a "clean" sound, but because what we would need for a gain pot would be something like 500K and 2 to 7 VRMS, which would make the distortion so high that only in a "rectifryer" channel would be acceptable.
Despite of being a tube preamp design, if I was an engineer at a big company, and even maybe if I just had the time, I would try VCA's or a buffered Digital Potentiometer.
If some company came up with that it would blow the market.
I know, solid state, thats a BIG NO NO!! But listen:
At the first gain control we only need to control 2 to 7 VRMS. A +/-15Volt supplied buffered Digital Potentiometer is enough for that, I think that would affect much less the signal than a LDR.
The biggest problem is that one can't use a standard tonestack because there are no DigiPots with higher impedance than 200K that I'm aware off, so a 4 band active Equalizer would be the way to go.
Well there is a lot of solid-state on a design like this, but who can say it will sound bad no matter what?!!
And look at something, for one of the Big Four, an estimate 10,000 units like this, for sure they could make it cost less that 100$ on parts and even they sell it for four times that it would be affordable.
For an DIY, this could be a two month fun...
Well, circuit theory tells us that if we make all of the resistors and pots in a tone stack 10 times smaller, and all the capacitors 10 times bigger, and scale the input and output impedances down by 10 times too, it will still have the same frequency response.
This is what I'd do if I were asked to make a digitally controllable tone stack, since I already have experience with hybrid amps and have got some good tones without breaking the +/-15V limit. I'd scale the tone circuitry from a classic amp to work with digital pots and multiplying DACs, and then make a completely fresh amp design to accommodate the lower signal voltages. I suspect the JMP-1 does something similar.
As an example, I don't think any tone pot in my old Ninja Toaster amp is above 100k or sees more than 30Vp-p. This was the result of using op-amps in the EQ. However, this introduction of silicon is the thin end of a wedge whose logical conclusion is a Pod.
Of course if you want an exact clone of a vintage amp that's digitally controllable, I guess you have to go down the road that this thread discusses. But to me that's like putting alloy wheels on a Model T Ford."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
http://www.datasheetarchive.com/preview/3342389.html
http://www.datasheetarchive.com/preview/3342399.html
JMP-1 schematic:
http://www.drtube.com/schematics/mar...jmp1-61-04.pdf
And by the way there are 1M digital pots /frequency response is 6 kHz/ but they are low voltage.
Hughes and kettner have the Switchblade series fully programmable tube amps. I wonder how they did it? This is how it looks inside /sorry, the picture is small/.
Originally posted by tbryanh View PostI am not sure what 'walking' means. Please explain if you don't mind?
Hope this helps!
Pots with relays
Clearly, on the bass and mid controls of the typical tone stack, a binary sequence of resistors can be used. (Those R/2R ladders always confuse me!) With 6 relays you could get 64 steps. The resistors might be 560K, 270K, 130K, 62k, 30K, and 15K (total 1.067meg). All resistors are in series and each one has a relay across it to short it out selectively. You get 63 possible resistances and a short. Lets call this a binary ladder. To emulate a log taper, 8 resistor/relays might be needed.
The same idea can be used to make a pot except you need twice as many relays and resistors. A binary ladder for the top portion of the pot and a binary ladder for the bottom portion of the pot. Although you could independently set the top and bottom resistance, it would be nice to keep the end to end resistance constant. To do that, you have to close (for example) the 62K relay on the top when you open the 62K relay on the bottom. So, you could use DPDT relays and arrange the contacts to do this automatically saving half the number of relays.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
The same idea can be used to make a pot except you need twice as many relays and resistors. A binary ladder for the top portion of the pot and a binary ladder for the bottom portion of the pot. Although you could independently set the top and bottom resistance, it would be nice to keep the end to end resistance constant. To do that, you have to close (for example) the 62K relay on the top when you open the 62K relay on the bottom. So, you could use DPDT relays and arrange the contacts to do this automatically saving half the number of relays.-Bryan
Originally posted by Steve Conner View PostOf course if you want an exact clone of a vintage amp that's digitally controllable, I guess you have to go down the road that this thread discusses. But to me that's like putting alloy wheels on a Model T Ford.
The issue I have is I want the best tone. Its true that if you have the best tone, you play your best. Its hard to be serious when you squeeze into a note that gives you that transistor fuzz. Sure it sounds pretty good overall, but that little fuzz takes alot of the excitement away.
It doesn't take an obvious large farty amount of transistor distortion to spoil things. Just a tiny amount of that transistor fizz still sucks.-Bryan
