I've got too much time on my hands.
I'm working on a design for a friend who wants a Princeton Reverb head with something to kick for the occasional solo. This goes over a 2X10. He was talking about a master volume but my thoughts are this design loses too much of a pretty limited gain structure.
I was thinking about a partial tone stack bypass -- recovering some of what is lost rather than losing more. There are three designs I'm playing with. This guy usually plays Tele's and slide 1/3 of the time so just lifting the ground is probably too much. In each of the three examples below, there is an extra pot and possibly a switch (prolly a push/pull pot). All of these are at least mostly stolen from better designers than myself so thanks to those who went before me.
The first one is basically a really big mid pot with a parallel cap to take a little bite off the highs. Pretty simple. The middle example is just a big mid-boost with a pot to control the increased signal and possibly a bleed resistor to not overwhelm the next stage.
Contestant #3 is similar to the Dumble PAB except I'm using a pot to separate the treble from the bass pot. The mid is set at half the stock value in that design. Usually this is a switch to separate the treble and bass pots but the bass and mid still bleed to ground. In the larger versions of this amp, the bass wiper and #3 lug are on a dpdt footswitch. I'm doing it here as a variable resistor.
None of the values are written in stone and I'm sure I'll leave a couple extra lugs on the board for tweaks. Still, if anyone wants to wade in with comments, improvements or questions, I'd love to hear from you.
Thanks, Skip
Thanks, Skip
