Hi there fellow valve-amp junkies
A belated merry eczemas from down under and the top of the festive season to you all
I'm designing a FW diode rectifier that is running off a secondary of 240-0-240VAC.
The PIV is (2 x root 2) x 240 (as I understand it) - which gives a PIV of 672V
I realise I probably don't need to , but (say if I wanted to) if I am using two 1N4007 in series on each side of the rectifier (for a bit of a buffer), can I get away with 630V caps in parallel with each diode? (see schematic)
Cheers
Cheers
