I have a EL34 build that i had spent many months tweaking....i'm sure some of you remember. (bad memories maybe
Anyways, i long since nailed the tone i was looking for and finally used it at a gig where i was relieved to find it exceeded my expectations. I have no reservations saying that of all the marshalls i used in the past, this sounds better. I was extremely happy. It has a very high gain preamp.
That said, there is one issue i have never been able to figure out. It's not a issue that really affects the tone in any way unless you play much louder than i ever do. But still it bothers me because i have several people wanting me to build them this amp and i don't want ANY flaws in it. Heres the deal....at extreme volumes a extremely ugly distortion sets in. We're talking almost full volume. I am fairly sure it is the PI being slammed too hard because it has a PRE PI master right after the tone stack ala JCM800. So we know it isn't happening before that because with full preamp gain it sounds godly till it's almost cranked. The way i first realized this was happening was that i installed a POST PI master at one point and left the pre master in too. When i would turn the pre master all the way up and used the POST PI master down, the sound would happen till i turned the pre master down a bit.
The sound is a complete turnaround....it's so ratty and buzzy it's horrid. Like pegging the needles on a mixing console sort of. And the bass completely disappears. So picture the worse OD pedal you ever heard and imagine turning it's OD all the way up and turning the bass off and the mids and treble all the way up.
So we know it isn't before the pre PI master because if it were it would sound like that at any volume if the gain knob is maxed. And we know it isn't the power tubes because with the post PI master way down it does it as long as the pre pi master is way up. See what im saying here?
This is where the thread title "unorthodox design" comes in. I have no idea why this amp does this, but i'm wonder if it would be worth trying to add a voltage divider right at the cathode of the cathode follower. Theres already a 100k to ground, so adding another R and messing with values, or removing the 100k and adding a pot to experiment. Or another idea, put a second pot after the pre pi master so as to have 2 masters in a row one after another, then with the first one all the way up, thru the second one down till the nasty OD disappears then replace it with a voltage divider of the values i measure at the pot when turned down to where it cleared up.
Thoughts?
Schematic...
http://s24.photobucket.com/albums/c3...urrent=amp.jpg
![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
Thoughts?
Schematic...
