Dual bandmaster design- plausible?
  • Dual bandmaster design- plausible?
    I have a defunct bassman 10 that I am converting to 5E7. However, given the huge chassis and tons of knobs, I would like to give each channel of the original 5e7 its own cathode-followed tone stack (yes i realize I need to add a tube. from what i read, this is not a problem for the PT).
    So each half of V1 would go to its own volume (like normal) and from there each to its own direct-coupled CF stage (V2&3 respectively), followed by the tone stack. They would then mix into the last stage (V4).
    I think this will be a really cool amp, but am not sure about mixing both tonestacks back into the last tube. I don't want the tone controls on one channel to affect the other channel. Would putting a couple of 470K mixing resistors into the final grid be sufficient? Or is this just a bad idea...
    Well, 2 volume controls (1M?), each with a 470k from the wiper to a common node (grid) would, worst case, be like another volume control at 50%.
    Worst case being one volume control at zero.
    It's not quite isolation, but better than nothing. If you're not going to be using the two channels simultaneously, a couple of series LDRs to select one or the other might be a better choice.
    Hope this helps!
      How many preamp tubes can you stand to have on the chassis?
      There is a very easy way to mix two channels into a single 12AX7 sharing a common anode or cathode....
      added:
      This will give you something crazy like 10Meg ohms of isolation...
      Bruce
      Mission Amps
      Denver, CO. 80022
      www.missionamps.com
      303-955-2412
        If I understand correctly it's like this:
        half tube - volume - whole tube - tonestack - to PI
        and
        You could at least try using two mixing-resistors (220k to 470k) coming from the tonestacks to the PI-driver-input-grid.
        Compared to the stock circuit the PI will (probably) driven somewhat "softer" but that cab be a +, depending on your sound-wishes. If it's too much you could (then) try lowering the amount of neg. feedback if needed to up the gain from the PI.
        Hope this helps!
        Love, peace & loudness,
        Chris
        http://www.CMWamps.com
          How about each tonestack going into the different inputs of the phase inverter?
          Some amps use the 2nd PI input for the reverb signal.
            These amps use a cathodyne driver/splitter... not a long tail pair.
            Can you see yourself clear to insert two more sockets?
            There are only three now but the chassis is huge....
            Another 9 pin socket and maybe a 7 pin for a 6C4 or even two 9 pins for a 12AX7 using only one half?
            The anode mixer is your answer.... the channel isolation is incredibly high.
            You'd use the extra, fourth socket as the single triode cathodyne driver.
            I drew this from memory (times two channels) so don't count on it being 100% accurate!!
            Main thing is to look at the anode mixing stage before the phase inverter
            triode.
            Bruce
            Mission Amps
            Denver, CO. 80022
            www.missionamps.com
            303-955-2412
