hey folks !
heres what i got ;
i want to make a hybrid . i have a solid state preamp that i really really like the sound of . its from a Road 115B (70s all ss bass amp) that i play regular guitar through . i was thinking of using it to preamp a tube PI/poweramp .
ive got an old peavey 'festival duece two' (hybrid) . figured i could remove the ss preamp/PI board and rewire the output tubes . its ment to be 4x6l6 @ 100w into 4 ohms , but for now ill run only 2 (and double the output ohms , 8 ohms instead of 4 ... right?) and use the extra juice for 2 preamp tubes .
as for the tube wiring part , i looked around , and then asked around , then looked around some more . the end result i was looking for was something to compliement the ss preamp (obviously?) . being pointed in the direction of the fender twins , i chose the silverface twin reverb .
i have more solid state expereince than tube , so i want to keep this as simple as possible ... plus i dont want to buy any more parts than i have to . i took the schematic from the twin reverbs and removed almost everything (i know i know ... sacralige/blastfemy , im commetting em all here) . i want it so that it will act as a poweramp , volume being dependent on the level of the input signal , so ill kept the normal channel w/ the volume control as a 'set and forget' trimpot on the inside .
my biggest concerns are with the power supply and bias arraingement . the peavey psu - rectifier/RC filter board , provides +480v/plate and +470v/screen as is . this should be fine for the 6l6s im thinking .
but how should the bias circuit be ? like that of the fender im mimmicing or could it be left peavey style ?
ive attached the sf twin and peavey psu/poweramp schematics i messed with (i can post the original unaltered versions for reference if anyone needs) .
id really appreciate any comments , pointers and/or constructive critisism .
heres what i got ;
