Hi all!
My name is sebastian and i'm really new to this forum. I have no previous experience with tubes, so I wanna build myself a tube amp. In the beginning of the journy I had chosen a design based on cheap radio tubes that I'd found in www.diyguitarist.com (its called Radio Head, its under Guitar FX stuff) to serve as preamp. I started building it and realized that perhaps it would be cool if I build various preamps in different cabinets and use them with a common tube power amp. So I looked up in AX84 site and found some low wattage (cool for my sound needs) tube poweramps.
The problem is that my budget is kind of tight, so I haven't got a lot of money to spend on the proyect. I know that I'll have to spend some bucks in the output transfomer, but I came to think that I could save some money if instead of using a big power transformer I use common transformers 220v / 6 v in back-to-back fashion as used in many DIY tube preamps, so the question I want to make is ¿Can I feed a 6SN7 or 6L6 tube like the ones portrayed here with a power supply based on back to back transformers?
