It looks like any other amp to me, what areas are not clear to you?
V1A is a classic Fender front end, then through a classic Fender TMB tone stack and volume control with classic Fender recovery stage V1B. The extra contacts on the input jacks are just there to ground off the volume control when nothing is plugged in. All that does is mute at a later point in the circuit for better quieting. Marshall does something similar a lot.
From there, we go to V2A, an active EQ stage configured as a graphic or at least a multiband. We also branch through V2B, a pentode driving the reverb. 6CX8 is an odd tube for Fender, but the circuits are pretty conventional.
The reverb output rejoins the signal with the ooutput of the active EQ at mixer tube V3C. There is a switchable bias supply tap for the grid of this stage to cause distortion when selected. 6C10 is unusual for Fender, but it is just triodes. This distortion circuit sucks, in my humble view.
V3A is a cathode follower that is switchable in cathode circuit to be part of the distortion circuit. Exactly what they are doing there I'd have to think about.
From there the master volume feeds a conventional phase splitter, with an NFB kill footswitch used as a boost.
V5 is a CF drive stage for that forest of power tubes.
That is the best I can do right after a big lunch.
But the bottom line is, the tip of the lower jack is always connected to pin 2 of V1B.
No, the tip of the lower jack is never connected to pin 2 of V1B. So all your therefores after that point are rendered invalid.
The tip of the lower jack connects only through the 33k resistor to the pin7 of V1A.
Pin 2 at V1B, aside from its own circuit, is ONLY connected to the two cutout contacts on the jacks, and through them to ground.
WHat you are missing is that the two vertical lines from the tip contact to the switched contacts above it is a mechanical connection, NOT an electrical one. It represents the plastic mechanical lifter that actuates those contacts when the tip contact moves. There is no connection between those switched contacts and the tip contact.
