This might best apply to higher gain preamps.
From AudioKarma and AudioAsylum threads I've decanted a few notables for us. I'll drop these in soon and report back. As well, I think even AAAs would be just fine.
One more point is that a rechargeable battery in cathode circuit does pass AC current freely. However, since these batteries have very low internal impedance (typically less than 1 ohm when fully charged), a few mAs of AC current only generate a few mVs of voltage, about 1/1000 of the AC voltage when a 820 ohm resistor is used. As such, there is no need for bypass cap and there is no negative feedback in cathode circuit, leading to much higher gain.
To get the required 2V on the cathode, I had to raise a 1.2V battery above ground, with a 280 ohm resistor. I tried the "D" cell, against the "AA", and the "D" cell definitely sounded better, with the 6SL7 driver.
Use some double adhesive tape to secure a pair of single AA battery holders within proximity of the spot vacated by the 1K/100uf cathode resistors/bypass caps. Solder the red [+] wires to the cathode and the black wires [-] to ground, and then install the batteries.
Since you are bold enough to use battery bias for the input stage, you might want to replace the resistor with a series of rechargeable 9 volt (7.2 volts, in reality) batteries. This would also define a fixed bias voltage that would be renewed when the amplifier is in use! [this is for biasing of the output stage]
LEDS
In every case, a battery or LED is far superior to having a cap in the cathode. I'll never allow that to happen again.
The cheapest red ones are 2.1V/2mA, which is fine for a 6SL7; yellow, green etc. come in 20-60mA ratings. The shorter lead is the cathode, which goes to ground. Place it in the cathode circuit, turn on the amp and watch it light up! The 2 volt versions will give you about 1.8-1.9 volts bias.
LEDS
