Amp is based on a Marshall JCM800 2204 circuit, with some mods and tweaks.
I ordered an 8" deep chassis (16.5 wide, typical) which allows some leeway compared to the standard 6.5"
I've included two images of layouts I'm considering (yeah, it's the real parts on a piece of paper! I'm a hand-on kind of person I guess). One I've dubbed "classic layout" since old Plexis were done this way. Downside is having all the transformers weight on one side.
Second one is a "modern" layout, similar to Soldanos for example, with the preamp tubes at the front (board fits in the middle), and the transformers at each end... not sure where to put the choke though. Those amps seem to have it inside the chassis (it would actually fit under the power transformer).
Edit: Front of amp would be on the bottom from this point of view
Any suggestions?
Many thanks!
Any suggestions?
Many thanks!
