MWJB: Yes, if the amp is running flat out and the speaker goes open, the screen grids of the power tubes will be destroyed in a few seconds like I mentioned. This is not the same as blowing the OT though, and the flyback diodes and resistor wouldn't prevent it. When I was testing this, I never took it all the way to destruction, but I saw the screen grids light up white-hot and there was still some way to go on the master volume.
Shorting jacks are still useful, I just wanted to point out that they're not 100% effective. Only 50% as the speaker cord has two ends and you could forget to plug in either one.
Neutrik now make "Silentjack" 1/4" jack plugs that short when they're disconnected, so maybe you could put those on both ends of all your speaker cords too...
As for the flyback diode rating, I think it should be as low as possible: if there are spikes flying around, you want the diodes to go before the OT does.
