Are there any cons to bleeding resistors?
On one hand, it "feels" good to know that you filter caps are always drained when the amp is not in use, but it also means they have to fully recharge every time you turn the amp on, causing additionnal stress and risking burning up fuses.
When I need to work on the amp, I can drain the caps myself, I can also temporarily hook a resistor to ground to make sure they drain if they "regrow".
Any thoughts on this?
Do caps last longer when charged most of time, or is it the other way around? (I think I've read that electrolytics are happier charged...)
