I'm working on a build using a pair of 6550's and a Fender Twin Reverb power TF. It seems most designs using 6550's are either ultralinear or use some sort of system to drop the screen voltage to around 300 volts.
If I run the screens up around the plate voltage (say 400-450 volts) will it be harder on the tubes than the normal lower voltage? I assume it'll take more grid 1 bias voltage to keep them turned off. Will this result in the need for a lower z bias supply and more grid drive or will it result in higher transconductance and gain. It's tough to tell from the datasheet I was looking at last night but I assume it'll take less grid drive but more bias voltage.
What about running the screens from a choke and a seperate pair of diodes? It seems like this would be simpler than a regulated screen supply but I don't know if it would work as well in the real world.
I once read that if you're going to regulate the screens you should regulate the bias supply...any truth to that in low fi guitar amp land?
jamie
jamie
