So I'd like to build a 6G15-like circuit into my tube amp project (as the very first stage). I did some preliminary fiddling around and I already got some good sounds out of that pan with some basic circuitry.
Now I'm looking at the "real" Fender schematic and I have some questions:
- What's with the use of those 2 halves of the 12AT7. They tap 1/10th of the signal of the first triode to the "dwell" pot and send that on to the next tube. Why didn't they work with just one half, without the voltage divider?
- If this has to do with polarity of the signal (which is my best guess), couldn't you just reverse the polarity of the send or return of the pan? It's just a matter of reversing the connection of the 6K6's output transformers secondary, right?
- Has anybody experimented with the value of the 250pF cap between the tone and mixer potmeter? Seems like an awfully small value...
Any other thoughts you might have are welcome; I'm making some changes to the circuit to accomodate it to the stuff I have lying around: I have a 4AB3C1B pan; the transformer I use to drive it is a Visaton 100V system transformer driven by an EL84 with Ua about 220V and Uk about 10V - for experimenting I used the 2,5 and 1,25W taps.
