I have a .68uf bypass cap on V1A and also on V1B. However, the V1B cap is on a switch as a gain boost. I have found however that the tone is better with both caps in, but the gain is too much for my normal setting. I have a 2.2k in series with the switchable cap, and i realize i could use a bigger value there to reduce the gain even further. But then the tone of the cap will be lessened. So what i want is the tone of that second bypass cap but w/o the extra gain. problem is, i've exhausted ways of getting less gain. I have a split load on V1B but not on V1a because that just seemed to hurt the tone. The cathode resistors are already pretty high, 2.2k/4.7k, plus changing those always seems to hurt tone because i settled on those values after months of experimenting and those just work best.
So is there a way to get the tone of that.68uf cap w/o adding more gain?
