What could be the cause of that?
I thought it might be bad grounding so I used my DMM and measured the resistance from the ground side of the guitar lead all the way to the groud lug on the power connector, and it came under 0.1ohm, so my path to ground is good.
All checked all my ground connection inside the amp, all seems good.
It does that with both of my guitars and the "real" Marshall doesn't do it, just the clone.
Any help would be appreciated!
For the record: I used "2-star" grounds, with the OT center tap joined with the first filter cap ground. Then I had a ground buss on the board (instead of soldered to the back of the pots) where all the grounds go (no loop possible) which is joined with the 2 other filter caps to the 2nd filter cap's bolt.
Power valve are grounded straight to the chassis via 1ohm resistors for biasing purpose.
