If I have two channels in parallel (one EF86 and the other 2x 12AX7 gain stages) they should be out of phase with each other when the reach the same side of the PI input. The other side of the PI is connected to the NFB/Presence circuit. I will have an extra half of a 12AT7 left over that I was thinking I could you an another gain stage and invert the signal coming off the 12AX7 channel and get the phasing correct. Does this sound logical?
Using the Triode Calculator here, I found these values for the 12AT7.
Rp - 11k
Rk - 10k (unbypassed)
Rg - 1M
Ri - 470k
Voltage Gain - 1.02
Decibel Gain - 0dB
Think it'll work?
Rp - 11k
Rg - 1M
Ri - 470k
Voltage Gain - 1.02
Decibel Gain - 0dB
Think it'll work?
