Hello,
I prepared a schematic for a power supply section with the intention of using a 50vAC "bias" tap to supply 48vDC as phantom power to a microphone.
I've only just learned that the transformer I selected is wired differently than I anticipated and as I had drawn in my schematic. I need to ask for help in understanding how to hook this up.
Here's my schematic (sorry for the size... I wanted to keep the lettering legible) that I know needs to be corrected:
EDIT: this schematic has been replaced with a more correct version as shown below:
So I am not sure what to do. Does the supply to the 5y3 need a center tap to ground? Can I just use the center tap and the 50vAc as my two connections to the solid state bridge rectifier sort of like I have shown? Or do I need to keep the center tap on the 275/275 connected to ground and float the 50vAC tap some other way?
Thanks for any help you can offer.
best regards,
mike
best regards,
mike
