Is it a waste to bias the 6V6GT's, there are JJ's at 60% ?
My 6G2 front end and 5E3 adjustable fixed bias amp has a plate of 405 VDC and the mA for one tube is 18.5 on average put it at close to 60 % of max . I am a bit confused because weber has a area for the bias rite that you put in the plate and it gives you a choice of a 6V6 or 6V6GT and from what I've read the GT is a max IPD of 14 watts.
The amp sounds good and solid bottom which I like . one chart weber has shows 70% for my late VDC at 24.1 and there is below a jim Jones chart showing a plate of 400 VDC and 60% gives 18 mA and a hot 70 % @ 21 mA and cold 50% but lets not go there.
My bias rite is a weber but does not have the plate so I keep the tube in the bias rite just so I can read pin 3 and get the plate without removing the chassis and I know the plate will drop as I raise the mA draw .
Mainly baising hotter say 70% does this bring more breakup of will it keep the bottom end or even bring the bottom out more .
Of course this does depend on the OP tube brand . I have JJ's in there now and have ruby 6V6GTBC coming as well as EH 6V6GT's .
My issue is to retain as much bottom end and keep the touch sensitivity there. This is with strat single coils . There seems to be little talk but reviews on JJ's having a piano type low end sound .
It's all so confusing and I can't A/B tubes so by the time I change and set the bias I can't recall how it sounded .
At one time I had a 77 MM bass amp with old RCA 6V6GTA's and then JJ6V6S and a 71 MM bass amp with the 6AQ5 output tubes and biased about the same and to be quite honest I could not tell much difference so I ask is a lot of this just hype or are we bordering on sales on certain tubes or insanity or is it just me? I am not gigging anymore so it's just here at home now days .
