When I built the two amp I have I used 500 volt sprauges or F&T and on my AA764 champ I used a 25 uf 150 volt cap on the cathode bypass resister because I had it and it fit . Both amps are no more than 3 to 4 years old and at that time I did not see 25uf 50 volt caps or I may have got them so I used the best caps I could get and what the amps were using when built way back when.
On both amps I used sprague 25 uf 25 vol caps and one 2uf 25 volt on the champ . Somewhere I read people use 50 volt preamp and second gain stage cathode bypass caps . If there is 1.5 to 2 VDC throught the bypass to ground what would be the harm in 25 volt caps or the advantage of 50 volt caps ?
I mean if over 25 volts appears through that cap what is a 50 volt going to save or are 50 volt caps more accurate or stable . Fender used 25 volt bypas caps on their twins and everything else. I was just wondering why , some go for 50 volt caps.
