Ok I know that a pot has a right and a left. I had to go and do it to believe it but can someone explain to me why you can't just wire pots oposite and it not work? How does this mess up the sound. I would seem that it should only change whether you would turn the pot clockwise or counterclockwise but it for sure changes the sound.
Also about Phase. On an amp like a Vibro Champ where the phase is opposite to the output jack as compaired to other amps like the twin, super, bassman. I'm guessing that there is a right way but how do you know the output phase of an amp without using test equipment. Would you just look at how many gain stages it has and figure the up down up down with the signal to see the final phase? Sorry for the stupid questions but I've gotten pretty far with amps and there is still a few basics that I really need to "know" the answer too and not just be able to figure it out with trail and error. Thanks for all the help. Especially you ENZO.
![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
