What are some of the ways to reduce the B+ to the power tubes in about half in an existing amplifier build?
The attached Fender 75 schematic shows a low-voltage tap off the filter caps.
The schematic appears to have an error. It appears the RED/YEL center-tap on the transformer should be connected to ground, not to the node between the filter caps (the low-voltage tap off the filter caps).
Is there an error in the schematic?
What other schematics are out there that have Hi/Low power switches in them? Any links to them?
What are some of the other ways to reduce B+ besides having a filter cap tap?
(I know Power Scaling exists, but I think the effort needed to have a knob to adjust B+ is not worth it.)
