I am beginning to learn basic CNC machining on a bench top mini mill. One of the things that is suggested as a potential project is the fabrication of prototype circuit boards using a procedure where the CNC mill is programed to etch or remove excess copper off of a fully clad board leaving only the traces that are needed for the circuit.
I stumbled upon a program named Eagle 5.60 that enables me to assemble a schematic and layout a board AND generate the G-code that is required to run the mill.
I'm learning to use Eagle but I work with old style discrete components like axial metal film resistors. The eagle program comes with lots of libraries that focus on modern form factors. Which leaves me to wade thru lots of choices looking for some simple part. Here's where I need help... I often end up with several choices that refer to the "package" description.
How can I learn what the official "package" description is of older style parts that I find familiar and have never described as such?
Thanks very much,
mike
Thanks very much,
mike
