I posted this over at Harmony Central, but I think you all might be able to help out more on this one. According to R.G. Keen's article, there are very few places in a tube amp where carbon comp resistors may be beneficial. He states:
So what are some applications that would be useful for a tube amp? It seems like he is saying that they might be useful, but there isn't really any place to use them. Any ideas?
First, they do no good and lots of noisy bad where the signal level is small and the following amplification is high - a classical description of an input stage. The input to an amp should probably have a metal film plate resistor to minimize noise. Grid resistors in all but output stages also do no good, because the signal level is typically too low. A 12AX7 can be driven from cutoff to positive grid voltage with a couple of volts of signal, so the grid resistor never has a big enough signal to be distorted appreciably.
Cathode resistors are another poor use of CC. They typically only have a few volts across them, and they're often decoupled with a capacitor, both of which would minimize the resistor distortion. In cathode followers, there can be substantial DC and signal voltage across a cathode resistor, but in this case, the resistor is driven by the low impedance of the cathode, and the voltage across the resistor is controlled by the grid voltage very tightly, so the exact resistor value doesn't matter much - there won't be significant distortion.
The place to use CC's is where there's big signal - plate resistors, and ideally the stage just before the phase inverter. The phase inverter would otherwise be ideal, with plate resistors carrying the highest signal voltage in the amp, but phase inverters are often enclosed in a feedback loop. The feedback minimizes the distortion the resistor generates.
