I am trying to think of an easy way of getting more 'verb before I have to change the reverb transformer on my latest DIY build (schematic on this thread http://music-electronics-forum.com/t14515/ ).
I've got a parallel triode 12AT7 reverb driver. The plate resistance (ra) is 11k on a 12AT7, so paralleling the triodes effectively does what to the plate resistance? (doubles it? or halves it?)?
The reverb transformer I'm using is a 22921 that runs 15k Pr to 8R sec. 22921 Fender Reverb Driver Transformer
The problem I have is that there is not enough signal being driven into the parallel triodes' 12AT7 grid(s) to make the reverb sing in a decent way. I have determined this because if I use a 12AX7 in V1 there is more reverb than it I use a 12AY7 in V1.
So I was wondering if I would get a better result using one half of the 12AT7 as a driving stage for the other 1/2 of the 12AT7, and then drive the RT off the 2nd 12AT7? (Or as an alternative, maybe using a JJ ECC832 with the 12AX7 1/2 driving the 12AU7 1/2, which would in-turn drive the RT?)
How feasible is that idea do you think? (anyone?)
Cheers
Cheers
