unidentified PT, how to establish what wire is for what...
  • unidentified PT, how to establish what wire is for what...
    hi all,
    I've got a 120w PT that is the same as those used in the first Ashdown guitar amp heads that came out maybe 5 years back. Trouble is, I don't have a wiring diagram for it.
    What is the method for establishing whats what ???
    I've identified the wires that're on the same winding with a continuity test and also measured the resistance between the wires.
    PRIMARY (I think so anyway)
    * white (connected to nothing else)
    * black-green: 1.5ohm (0v-120v)
    * black-yellow: 4.1ohm (0v-220v?)
    * black-red: 4.7ohm (0v-240v?)
    * black-blue: 1.4ohm (0v-110v?)
    SECONDARY (hopefully)
    * green-green: 0.3ohm (heater winding, end to end?)
    * green-yellow: 0.2ohm (heater CT?)
    * purple-purple: 2.4ohm (winding for relays?)
    * black-blue: 11.9ohm (bias?)
    Does this look right?
    HTH - Heavier Than Hell
    its ok folks, I got this sorted.
      I'm assuming this is for a tube amp, since you referenced "heaters."
      Have you already identified the HV B+ secondary, or is it possible that it's mixed up with your primary connections?
      You could feed 6.3 vac INTO the two heater taps and measure your primary voltages. Use due caution!
      Nathan
        Whoops. Logged out, logged back in again and you had it sorted! Well done!
          Nathan
          thanks Nathan, I ended up doing exactly what you suggested - feeding 6.3vac into the heater winding. I was 90% certain of the taps before this with the resistance measurements I took, but I had to know.
          a mate of mate suggested putting the 6.3vac through the primary and that does seem like a good suggestion - its way less voltage than the primaries are used to taking, so no fear of toasting anything.
