I've just got back from repairing a bunch of monitors for a local band and of course the topic of tube amps came up.
It seems the hamonica player is very interested in what he describes as a "Hot tube amp with great distortion"
I found this schematic a while ago thinking it would make a great harp amp.
It was designed for a 6L6G but I will substitute a 6BG6GA.
Other than that I translated his schematic "sketch" verbatim (attached)
From the sound clips he had I REALLY liked the sound, but I have a few questions about his circuit. (he's never answered my querrys)
first is how the volume is applied. I've seen similair designs like that on phono amps but only between the input and first gain stage. Is this a preferential aplication? what would be better?
Second, I'm told the mic he prefers is a Hi Z Xtal mic. Is this input suitable?
Third, he never called out the coupling caps values and I ubiquitiosly chose .1uf as a starting point. What might be better values to start with?
Finally I've got everything in my bins right now to build this with the exception of an OT. I recently went thru all my OT's and hooked them up to a wall wart xformer and wrote thier calculated impedances in sharpie on the frames. I've got a hefty 7K6 primary to 8/4 sec. PP OT from an organ chassis. Could this be used if I do not connect the CT on the primary side?
any help or opinions are as always greatly apreciated.
Ray
****EDIT***
V1 is an octal 6SL7GT
Ray
****EDIT***
