I haven't been posting lately because i've been quite happy with my amp. But i lately have decided to add some gain to it and if you recall i had removed the voltage dividers between stages long ago and instead used 100k resistors from the 2nd and 3rd stage grids to ground, as you see in the schematic below. I can raise the gain considerably just by upping the value of either one. But my question is which would you change, the second stage or third? Or would you do both ? I can of course swap back and fourth and liten to what seems best, but is there a theoretical best way from looking at the circuit ?
