wha?
Most Musical Tube Amplifiers by Milbert Amplifiers
the designer reminds me of George Steele the old wrestler...but he seems to have discovered a couple dozen seemingly impossible design innovations...
quote:
"# Auto-Everything™
Automatic bias; Automatic idle/standby; Automatic World Power Ready with Power Factor Correction; Automatic loading. Never adjust bias again. Fly from standby to full power instantly upon demand. Plug it in and enjoy anywhere in the world, right out of the box. Drive it safely into any load, or no load.
# Play-Any-Tube™ -- Play 4 different power tubes at once if you like. Or 3. Or just 2.
Plug in any combination of 6L6, 6V6, 5881, 6550, KT66, KT77, KT88, 6CA7, or EL34 and it just works. Mix and match any combination for sound; Obviates "matched pairs" or even matched types! Power tubes can be changed readily or removed to reduce output power; the GAGA-50 will continue playing, albeit at reduced volume, should one or two output tubes fail during performance. details
# Drive-Anything™
Single output drives any reasonable combination of speakers, cabinets or loads. Nothing to set, match, mismatch, or confuse: one output does it all. Operation is optimized for 8 Ohms loads.
# Blow-Proof™
Reasonably sustains dead-shorts or no-load / total-opens without self-destructing. No more fear or blown output transformers as with typical tube amps.
# Power-Step™
Adjusts volume level vs. output power tube distortion. Not merely an attenuator, 'power soak' or 'hot plate' but a method that wastes no sound or energy as heat. details
# Super-Infra-Sonic™
Uncommonly wide bandwidth, flat frequency response down below 20Hz at full power. Plays airy highs with harshless alacrity and infra-sonic lows approaching DC voltage. details "
hmmm a flat frequency response, just what I want in a guitar amp...
opinions?
man his web site reads like a Dr Bronner's bottle...
quote:
"# Auto-Everything™
# Drive-Anything™
# Blow-Proof™
# Power-Step™
opinions?
