unused PT filament windings?
  • unused PT filament windings?
    I'm looking at the Hammond Transformer listings and it seems most of the time I see a suitable voltage and current capacity for the power tubes that the transformer also has 5vAC heater leads.
    It seems that there aren't many suitable B+ with 6.3vAC choices that do not also include 5vAC.
    That's great if you are running a tube rectifier.
    What do you do if you want to assemble a bridge rectifier out of diodes?
    Do you just terminate or find a use for the 5vAC leads? Shrink wrap? A Pilot light?
    thanks,
    mike
    ...ALL unused windings should be taped/insulated and otherwise left alone.
      Yep I put a couple of layers of heat-shrink overlapping the bare end of each unwanted wire, and tuck the ends away somewhere where they ain't going to cause grief (but keep the wires there for a rainy day).
        thanks.
          Personally, I prefer to have the unused wires terminate on a terminal strip. But that is just another way of keeping them out of the way of everything else as suggested above.
            How about using plastic insulated twist connector nuts. One for each wire.
              ...unless those "house electrician twist nuts" are firmly tied-down somewhere, they'll "rattle" like mad inside a chassis when vibrated.
              ...shrink tubing and tie-wraps work well.
                The bottom line is this, no matter how you do it, you want the wires secure, and unable to touch something else electrically. The transformer itself doesn;t care at all whether you actually use the winding or not.
