Originally posted by Albert Kreuzer
View Post
Any 8X El34 amps here?
Originally posted by Alf View PostImho I think this circuit was designed for playing (or passing) a clean signal, so who wants clipping at the front then ?
I would remove it .
What is inductance of the choke ?
Alf
The signal has to be higher then the threshold of 1.4V to get clipped; in this setting it'll protect the FET. I'd rather use an end to end diode setting with one end to ground, one end to V+ as it is normally done.
Can't read inductance here; no Henry on my DMM
Question:
I've seen most amps work with simple caps to ground as power supply filtering.... now this amp has bleeder resistors over em. What is the advantage of that?
link to pic
I found in a good source that they are also used as ways to get both caps the same load so not one is quicker then the other. Makes the 'new' value (2 caps in series) more stable.
My question is more on the soundwise; how is it compared to the standard cap to ground? I think I'll swap em for 47uF caps as I can get em in the right voltages pretty easy.
can anyone explain that to me? i've always wondered why.
surely two identical capacitors would have the same resistance?
is it just because the resistance of the capacitors is low, so resistance in wires etc. would affect the potential divider that's created by the capacitors?
Originally posted by harry View Postcan anyone explain that to me? i've always wondered why.
