Some brand use "power scaling " to obtain smaller volume sound , some use embbeded attenuator, in fact " power scaling" reduce the volume by adjuster the Voltage of transform and tube, It seems effect style.But attenuator cause very warm during it wast the power. which one is better
"power scaling" or attenuator
Well, the attenuator has the benefit of allowing the power tubes to run at full plate voltage, which I think keeps the amp from sounding too dark. Most other power scaling circuits drop the plate voltage to keep the plate current in check, helps extend tube life, but I think it colors the tone too much. Which one being better, is going to end up being up to the player.
-g
"Which one being better, is going to end up being up to the player."
I agree that the answer to this is subjective, which is better depends on the player's personal biases. Not all attenuators, nor all "power scaling" circuits, are designed or built the same way. Different designs offer different performances, and again, which is better is subjective, the answer depending on individual players perspectives and biases.
I don't believe there is a universal true answer to the question, only individual preferences.
I see their R&D dept is hard at work again (to quote from the mangled english on their home page) "We insist on combining creative western engineer's design"
Go down to the demo shop of your company, take an amp, and run the speaker output into the amps input. Then turn all the controls to ten.
That should cut down on the amps output power successfully.
Originally posted by kldguitar View PostSome brand use "power scaling " to obtain smaller volume sound , some use embbeded attenuator, in fact " power scaling" reduce the volume by adjuster the Voltage of transform and tube, It seems effect style.But attenuator cause very warm during it wast the power. which one is better
-g
I'm gonna go with Bruce's answer. In fact, when I first read this post (then noticed who it was from) I passed it up. Like I never have an opinoin
Chuck"Take two placebos, works twice as well." Enzo
