Hi, I just spent 3 hours surfing the net and found no complete answers; HELP!!!
I have an output transformer from an old PA amp and need to ID the leads. This is a PP tranny with CT. I found a number of articles about using a test power source and measuring voltages to determine the turns ratio, but no one speaks to the PP CT tranny. I don't know if I should just bypass the CT? Or read using the CT and only 1 end of the primary??? Also I read where a 6L6 tube wants to see 4k to 5k impedance, again is this on half of the OT??? Also I was thinking of using 4 6V6's for power tubes, so how do I calculate the impedance of 1 pair in PP with a second pair??? Every thing I've read so far has confused the issue. Any help would be greatly appreciated
Thanks
D
Thanks
D
