I'm planning to use a mosfet as an active screen voltage regulator- not so much a regulator as an active resistor. Take a look at this:
http://www.triodeel.com/gromm260.gif
I have some mosfets with a drain-source breakdown voltage of 450 volts- less than the intended B+ of the amp I'm building. I'll set the gate voltage with a divider like the grommes schematic. In order to avoid exceeding the breakdown voltage during startup I'll have a divider at the source as well- maybe a pair of 220k 1 watt resistors. Once running I'd want the source to be at about 350 volts where it would power screens, PI and preamp.
Will it make smoke or sound?
jamie
jamie
