Take a look at the two attached schematics for a Selmer Treble N Bass 50. The earlier version, MKII, only has (3) 12AX7 preamp tubes, whereas the later MKIII model added an effects loop and thus a 4th 12AX7 to drive it. So, the earlier version only has two gain stages, both sides of a triode per channel, while the later version adds a third gain stage that is shared by both channels (one half of the extra 12AX7 only) following each channel's respective signal travel through both halves of its particular 12AX7.
A few questions: (1) Does it matter *which side* of this extra triode is used? For example, if the signal coming off V1 or V3 (each channel, respectively) is on the side of the triode using pins 6/7, should the next stage enter in on 1/2 or 6/7? Or does it matter? Thinking of oscillation potential here.
(2) If you look at the MKIII schematic, when they added the extra stage, they added an extra resistor AFTER the two 470K mixer resistors off each channel. The signals from the respective channels travel through each 470K mixer, then prior to entering the extra gain stage of the MKIII they have to travel through a shared 1M resistor. WHY? Was this added to knock the signal back a bit to avoid excessive gain? I'm very interested in *why* this may have been added, and can it affect the sound other than to reduce the strength of the signal prior to entering a final gain stage? Or can it be serving some other purpose? They also added a .022 cap just prior to the last gain stage, which seems to defeat the purpose of using larger .047 caps as couplers? Isn't the .022 just going to further cut low frequencies? Maybe a slap-dash adaptation to orient it more towards a guitar amp as opposed to a bass amp?
I realize these are burning questions which are of intense global interest. I've been dwelling on them, that's for sure.
