A friend of mine just picked up a BF Super Reverb and he was telling me the reverb on it is crazy good sounding compared to just about any other Fender with built in reverb he's heard. So what I'm wondering is, how much does a tank play in the overall sound of the reverb circuit versus the variance of parts values in the circuit itself?
I've seen guts of the amp and so far as I can tell, the only mod it has is a cap across the tank input to ground that I assume is to filter out some high end/reduce noise—I guess this was stock on some later SF amps. In his case I worked out the .001uf cap would cut off around 10khz if the 15kΩ measurement for the reverb transformer I found is correct. Doesn't seem like that would have a dramatic effect on the tone of the reverb on its own.
