I'm trying to get some consensus here on the PI resistors; assuming the changes are being made in the same amp, what will it do to the PI (12AX7) if the resistors in the LTPI illustrated below are changed from 820 ohm/6.8K to the 'common' Marshall values of 470 ohm/10K? Would this change cause it to clip or distort sooner?
PI biasing - resistors
The bigger the tail resistor, the smaller the output signal swing from the plates will be, but the better the balance will be between the plate's outputs. (However it is this imbalance which produces the growliness in LTP inverters, so if you alter the tail without altering the Plate resistors, you will theoretically change this growliness. Whether this increases or decreases the growliness depends on whether you have already compensated for the imbalance by having different value plate resistors)
Also whether changing the tail resistor will result in signal clipping in turn, depends on how high the HT is. The higher the HT, the bigger the tail resistor can be whilst still getting enough output signal to overdrive the output stage.
Changing the tail will also affect the GFB that is required
Whereas if you increase the LTP bias resistor (colder biasing), you will reduce the PI output signal swing, but you will encourage cut-off clipping in the LTP (i.e. more PI overdrive)
Well that is LTPs as I understand it. Somebody else is most likely to have a much better explanation.Building a better world (one tube amp at a time)
So if I understand you correctly (1) changing the tail resistor [and I'm talking about the 6.8K here, not the 4.7] to a higher value *may* [depending on other things you mention] actually decrease 'growliness' as you put it or otherwise clean up the signal, and (2) decreasing the 820 ohm to 470 ohm "Marshall" value will actually clean up the sound? That's odd, because typically with the preamp tubes, lowering the cathode resistors often creates a dirtier sound. Hmmmm.
Originally posted by EFK View PostSo if I understand you correctly (1) changing the tail resistor [and I'm talking about the 6.8K here, not the 4.7] to a higher value *may* [depending on other things you mention] actually decrease 'growliness' as you put it or otherwise clean up the signal
Originally posted by EFK View Post(2) decreasing the 820 ohm to 470 ohm "Marshall" value will actually clean up the sound?
There are many variables to consider. How much voltage will it take on the power tube grids to drive them to full power and beyond? How much plate voltage is on the PI? Is the amp class A push pull, a hot AB1 or a cool AB1 bias on the power tubes? Does the amp use NFB? These are some things that effect PI design for a particular amp and keep PI design from being like, for example, tonestack design. Where the tweaking process is limited somewhat to the function of only that part of the circuit. The PI has a job to do that is relative to power tubes state AND usually within the FB loop so you can't effect the tone of the PI without effecting the state of the power tubes without effecting the FB loop which now effects the PI, etc. etc. So the PI design is PART of a bigger circuit and can't really be considered by itself for tweaking.
Randall Aiken has a great tutorial on the LTP PI values and how to build a PI for proper "function" that may shen a little light:
Long-Tail Pair Design
Chuck"Take two placebos, works twice as well." Enzo
Long-Tailed-Pair Phase Inverter Gain Calculator
Here you can calculate the differences
Very handy site !
Alf
