The final kicker on the amp I'm planning will be to have a pair of EL34 and a pair of 6L6GC, with the option of running all 6L6GC.
I loved what that did on my Mark IV.
I'm trying to stick with "off-the-shelf" replacement transformers, cause I'm broke and they're cheap, and mostly I can literally get them off the shelf at the local surplus store!
At first, I wanted to use a Plexi 100W set.
But I'm afraid this could melt 6L6s because of a screen voltage that's a bit too high.
What I learned here is that, since 6L6 don't draw much screen current, the resistor doesn't drop much voltage, therefore they would be mostly likely idling at about 480V on the screens (max is 450V for 6L6GC).
So I figured a PT for a Fender Twin Reverb would do the trick, with about 450V on the plates. Plus, with 450mA current capability (vs 300mA for Marshall PTs), I should be able to get a huge low-end by virtue of the power supply being up to the task.
Only problem is the filament winding is not enough to run 4 EL34s if I so wished. Not a big deal though.
Actually, it's not even enough for 2 EL34s, but I'll have an extra 4A transformer for the preamp tubes anyway (no off the shelf PT is up to the task, and the extra filament PT was 12$)
Sounds good so far?
To be clear, I'm building a 3 channel metal machine. I notice most Mesa run on about 450V, so I guess this should be good.
Now, about the output transformer, this might sound stupid, but I'm worried that the Fender Twin OT is too small.
If I look at the Hammond specs for example, the 100W Marshall is 8lbs, while the 100W Fender is 5.5lbs.
Another problem is the Fender only has a 4ohm taps, but Magnetic Components makes a multi-tap version.
The reason the weight bothers me is that, since this is to be a metal machine, I need the biggest low-end possible, and usually more iron = more low-end.
So based on that, the Marshall one appears the best option, but I'm wondering about the primary impedance...
The Marshall one is 1.7k, while the Fender is 2k
If the Marshall with EL34s sounds good at 495V, it should sound good at 450V too (what I mean is, when you lower voltage, you'd lower the output impedance too, not the other way around).
I've drawn the loadlines (though I'm no expert) and if anything, at 450V it crosses the dissipation limit less.
As for the 6L6GCs, I read they usually like a higher load, though this usually means even more than 2K anyway. Drawing the load lines, I notice it would stay in class A territory for a narrower portion.
To be fair, I'd rather use the Marshall one since I can then buy everything from the same vendor and save on shipping, not to mention they have it in stock at the local store (the Hammond one that is, I used the 1750N in my Plexi clone and love it)
And the heavier weight makes me feel more confident.
But if 15% different in impedance makes an audible impact for the worse, then I need to reconsider.
Any thoughts?
Many thanks!
Sounds good so far?
Any thoughts?
Many thanks!
