Originally posted by defaced
View Post
Meaning, when I choose a power transformer for this setup, should I also be accounting for the current the grids will be conducting when driven into AB2?
And if so, about how much current will that be per grid?
Good question. Tube data sheet will have some info on that. It depends a lot on how far you drive them into conduction. But it will be nowhere near the plate current, as the surface area of the grid in the electron stream is nowhere near the area of the plate. And it'll be comparable to but larger than the plate current of a driver tube. I'd call it 5-10ma to start with.
About the zener ripple rejection. The current rating for the zener is the current that's going to be dumped to ground as part of the regulation, correct? I'm making sure the transformer I'm looking at is up to the job before I get too far ahead of myself. I'm not used to counting milliamps, in my day job, 5 amps is the smallest increment I care about.
A zener regulates by eating all the current it's allowed to by the current limiting device in series with it (usually a resistor) and the load which siphons off some of the current. If the load is zero, the zener eats all the current it can. When the load eats all the available current, the zener can no longer regulate and the voltage sags. Between the two, the zener holds the voltage approximately constant as the load varies.
So to design a zener regulator, you first figure out or estimate your load current and its variation. If the minimum is zero, it's zero and the zener has to be designed to eat all the maximum current. If there is a minimum load, the zener can be designed to eat only the min-to-max currents. You then pick a zener which has the right voltage, and has enough power rating so that zener voltage times the max current in the zener (which happens at minimum load current) is smaller than the zener power rating plus any safety factor you want.
Finally you calculate the limiting resistor, sizing its power rating for the max voltage times current it will see, and adding any safety factor.
If you're a don't-burn-it-up kind of guy, you'll then go back through the calcs for what happens when the load goes to truly zero (cable broken, maybe) and when the zener and/or load is shorted.
